    Dismiss Notice
Adding extra radiator to existing system
Discussion in 'Plumbing and Central Heating' started by Daitheboot, 4 Dec 2007.
  1. Daitheboot
    Daitheboot
    4 Dec 2007
    2
    Thanks Received:
    Carmarthenshire
    Country:
    I have an existing system which is working very well. Condensing boiler, pumped system ,conventional indirect hot water tank in airing cupboard, rads in most rooms. My question is I would like to add a radiator in my conservatory. The existing system is 15mm but I would like to use 10mm microbore for the extra rad. I have located the tapping positions and the pipe run would be much easier if I can use 10mm. If this is not adviseable I will do it with 15mm.Is there anything special for me to look out for when restarting the system after fitting
    many thanks
  2. Sponsored Links
  3. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    10 mm with f&e will give you a good chance of future problems
  4. sanj.varah
    sanj.varah
    2 Apr 2007
    156
    Thanks Received:
    Country:
    I just steer clear of 10mm full stop.
    15mm has double the bore area of 10mm, so i would go with that unless its an absolute ball ache.
  5. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    1,001
    Country:
    Use 15mm & I believe you must have independent means of control & isolation of the radiator (not just the rad. valves) to keep BC happy.
  6. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    don't tell me they have yet again come up with some nonsense addition. any idea which ad that is in?
  7. Sponsored Links
  8. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    1,001
    Country:
    Not sure exactly what the regs. say but it's been the case for some time. Cons. doesn't normally come under building regs. & so the insulation levels are not controlled. It's all about energy conservation & is the same reason you must have an external grade door fitted between the cons & the house! I don’t think requirements are onerous, just means the heat from the radiator has to be controlled & capable of being isolated but you need to check the regs.
  9. Daitheboot
    Daitheboot
    4 Dec 2007
    2
    Thanks Received:
    Carmarthenshire
    Country:
    Thanks Guys for the advice. 15mm it is with isolating valves fitted at the tapping point.
    Useful info about the door needing to be exterior quality , didn't know that.
    Dave
  10. D_Hailsham
    D_Hailsham
    18 Oct 2007
    10,587
    Thanks Received:
    1,342
    Kent
    Country:
    Approved Document L1B "Conservation of Fuel and Power in Existing Buildings"
    Conservatories and substantially glazed extensions
    22 (a) Effective separation from the heated area in the existing dwelling. The walls, doors and windows between the dwelling and the extension should be insulated and draught-stripped to at least the same extent as in the existing dwelling.
    (b) Independent temperature and on/off controls to any heating system
  11. bengasman
    bengasman
    28 Jan 2005
    34,181
    Thanks Received:
    3,124
    London
    Country:
    thought for a moment that some mug had decided we needed to fit service valves on the rads
  12. Redhotferrari
    Redhotferrari
    11 Sep 2007
    769
    Thanks Received:
    31
    Country:
    10mm copper is the work of the devil, use 15mm
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
