Had a search but just want to clarify something.
I have a 2.8kw single oven (gas hob) - there is an existing 4mm cooker circuit which I plan to reuse (on a 32amp breaker atm).
Can I run the 4mm to a fcu and then a smaller size cable to feed the cooker (2.5)? Or does the outgoing cable need to be the same size (4mm)?
Other option is to add it into the existing ring I guess.......
What's the best practice here?
Cheers
Cheers
