Baxi Solo 2 PF ( I think I need a new PCB,have you got one?)
31 Dec 2007
Southampton
Hi, I don't know a lot but I am have a problem with the above boiler, it will not fire up. I think it is the PCB. What leads me to this is:-
the boiler turns on, but no fan operation although the front panel led tells me its working.
The PCB has dark brown overheated make just off off the middle and testing the feed to the fan which I believe should be 325 VDC there is none (I have the outer casing off and the air tight inner casing is also removed
Do you think I am right
Crowds :? :? :? :? :?
The voltage to the fan is 230v ac, how many lights show up, the pcb go regular on these models as do the fans.
and dont forget the old gas valve, which can some times send wrong information back to the board
no checked pilot solenoid, it is a very rare fault but it turned out to be the main solenoid on the gas valve,
had to change the complete valve.
It would be interesting to know
can you post it in combustion chamber so we can read it?
