I installed a false ceiling in my kitchen together with low voltage lighting before 2005. (introduction of Part P I beleive). Should I have connected the metal frame of the false ceiling to earth?
What that document doesn't consider is the case where a cowboy comes along after you and doesn't fix the cables properly. if the grid isn't earthed and it digs into a poorly fitted cable.......
