Why would it be expelled? Where from/to? I don't understand what you mean.ChrisH said:I agree that that might be the case, but then when the EV was pressurised the water would be expelled and would increase the system pressure, possibly above the 0.7 bar aimed for.
No it doesn't! If you remove the insert from the exv fill valve, (say it's at the top, thinking of Ideal Responses because there are so many in trouble!) the air pressure within will go to 1 atmosphere. And sit there. The water itself doesn't (de)compress so won't force all the air out.Agile said:Those others may disagree but if you want to do the job properly you must let ALL the air out with the system still pressurised, that indicates that the diaphragm is still intact and not leaking water to the air side
Agreed - its what I say In the FAQ I believe. The difficulty is that bit about leaving the system open to the atmosphere. HOW? If you open anything lower than the boiler, it'll empty forever, as air goes in through the AAV. If you let 10 litres or so of water out, that's enough to empty any boiler's exv as far as it'll go (the diaphragm may be stretched halfway across), and also let you pump it up in one go. There will be a few litres of air in the system, which can compress as you empty the exv completely.Agile said:Then you have to open the system to atmosphere and LEAVE it open as you pressurise the air to about 0.9 Bar. Doing that will force remaining water out of the EXV to make it empty of water.
This does mean that there will be some air in the system. Some will go out of the AAV of course, but not all.
Another way to do it would be to pressurise the exv to say a couple of bar, bleed a rad until the gauge reads zero (EXV full of air) then let the exv pressure back to 0.7/0.9. Is this what someone else said?
