Hi there,
I'm not sure if this has been covered in the past, I apologise if it has.
Basically my hot water works fine, nice and hot, however recently the central heating has not been working properly. For the last 3 or 4 days the CH hasn't come on in the morning or the evening while being set to timer and even when you flick the switch to constant it still doesn't work. It does however fire up and sound like it's working for say 20-30 seconds and then turns off again and stays off for ages again. The pipe coming directly from the boiler to the first radiator is really hot but as you follow it to the radiator it gets cooler and cooler and hot water doesn't reach any of the rads in the flat, we've only 4 it's a small flat!
Does anyone have any ideas as to what might be happening? I've read other posts and I'm thinking it could be something to do with pressure in the system but I'm not sure?
Any help would be greatly appreciated, thanks in advance
Pete
Pete
