Now that you mention it they do remnd me of Jehovah's witnesses's, you certainly wouldn't answer the door to either of them would you?
Gimme your address, cm, and I'll send the conservatively dressed boys round.I for one look forward to the new watchtower
Blimey! You're more open-minded that I thought.corgiman said:...Mrs CM ... is a very very strict proddie
I s'pose it pays the bills though?
My mistake - I thought you wrote "prossie".corgiman said:
billybob wrote
Heat pumps work on the priciple that for every 1kW of electricity used to power the heat pump, the heat pump will produce 4kW of heat, the physics are different as the two work in completely different ways
I understand that.![]()
As I have already stated I am talking about LATENT HEAT or to use the more modern term " Enthalpy of Transformation".
Yes, but the latent heat in a condensing boiler has been produced by the boiler within its specified capacity, the boiler simply catches this latent heat and extract most of the heat from it, I say most as some still goes out the flue, but this heat is still from the heat that the boiler produced, the fact that a small amount of this heat escapes out of the flue proves that the boiler has to be less than 100% efficient 95%-98%
So this is a load of rubbish in the following link compiled by Viessmann then......... ?.
http://www.viessmann.co.uk/downloads/CondensingTechnology.pdf
Amateurs.![]()
While I do not have Jehovah's witnesses round (there is an opt out), I have found them to be always very courteous and polite. It is unjustified to compare them with half wits that post here.
