Ben, it's the predecessor of the Solo.
predecessor
Does it have a name? For some reason, there don’t seem to be a lot of solos in my area, and doubt that I have seen a lot of it’s dads so to speak.
[/i]
pump seems fine, making a noise so I assume its running, turned to number 2/3 etc and sounded as if it were going faster.
predecessorblimey, what did that run on, Zeppelin gas?
[/i]
Then it'll be a motorised valve that is not opening.
You can open them manually,if you can find it.
Might be close to the pump it may be a Honeywell in which case it will be a gray box on the pipework with a small lever at the side which you move to the 'manual' position or it may be another type such as a Danfoss in which case you have to remove the power head and turn the valve by hand or pliers.
You might have to leave your heating programmer switched to 'hot water' or 'hot water only' and if there is a cylinder stat you may have to temporarily remove if from the cylinder.
Could still be the pump though,is it 'red hot to touch'?
And, I mean burning hot.
BTW,this is an old boiler but your boiler is working fine.
No the pump is more than likely knacked.
The impeller isn't moving but the motor is which is why it is red hot.
You probably on gravity hot water and pumped heating which is why the hot water is ok.
Finally got someone out, and finally got heating.
It was the motorised box next to pump not turning water on, to heating on etc. He said that they probably cant get that box these days but will still look for one, in the meantime they have knocked up a handle which allows me to turn in manually.
However, the boiler still doesnt fire up when you turn heating on from the control box, it does come on when you turn water on tho so im not cold but have called them back to check that its still ok.
Your thoughts?
