Hi, there's probably a simple answer to this. I'm running cables on a 'tanked' wall and want to know the best way to adhere the pvc channel to the wall, hope you can help cheers
the plaster should hold it quite well.. but to hold it in place until it's plastered over, try double sided tape.. or a few dabs of "no nails" or similar construction adhesive..
Do you mean channel? That could be tricky. PVC trunking might be better.
You could stick with Gripfill or silicone perhaps. Just so long as its not so heavy that it will rip of your tanking.
