Damaged kitchen door
1 Feb 2008
Isle of Wight
One of my lovely children decided to swing on a fitted kitchen door and ripped the screws and the hinge off the cupboard carcass, which is made out of chipboard. Can anyone advise me of the best way to repair the carcass so the hinge will get a strong fixing again.
Matt
can you post a pic so we can see how bad it is?
http://www.diynot.com/forums/viewtopic.php?t=99672
You might get away with just using thicker screws
If the cabinet is next to another one and they are fastened together, you can even drill the holes deeper, so they go part-way into the next cabinet, and use a longer screw. this will not work if there is already a hinge in the other cabinet at exactly the same point. If there is no cabinet on the other side, you can put a block of wood on the outside of the cabinet and use a longer screw into that.
I expect the hinges you have got are fixed into a large round recess machined into the door. But you can also get hinges that are surface mounted, so you can put them anywhere you like (you can also get a bit to make the round holes, but if you are not used to woodwork you might accidentally go right through)
