Hinges for Kitchen Cupboard Door
21 Jan 2011
Suffolk
Afternoon all,
Are there any kitchen fitters about?
My wife has been moaning for ages about the fact that it is difficult to see what's at the back of the larder cupboard in our kitchen. To solve this problem I have bought some of those wire baskets on runners that you can put inside a kitchen cupboard to make accessing the stuff in there easier.
The problem I have is the baskets are almost the exact width of the inside of the carcass, and when open the door ovelaps the opening by about 5mm and therefore the wire basket will not slide out.
I obviously need to change the hinges, but does anyone know if it is possible to get a concealed hinge (the type typically found on kitchen cabinets) that allows the door to swing right out of the way, or at least to a position where the inside face of the door is inline with the inside face of the carcass when the door is open (if that makes any sense)?
Any suggestions will be gratefully received.
Regards,
Rob
Afternoon all,
Regards,
Rob
Are they kitchen unit draws, they are designed to avoid that problem and sit 20mm off the hing side and are adjustable to avoid hitting the door, maybe you bought the wrong type.
