I recently fitted a combi-boiler. Everything is fine when i only put one hot tap on anywhere (12-13 litre/min) in the house, but if i put a hot tap on upstairs and then open a cold or hot tap downstairs i lose my water flow upstairs. So i changed my mains water stop cock from 15mm to 22mm and put a 22mm feed from it to a Tee. From this Tee my household cold water is then supplied in 15mm and also my 'DHW' through my combi boiler in 15mm. I want someone to recommend a booster pump i can fit 'in-line' directly after my stop cock which will supply both my combi and household cold water. I know i should have a break tank but are willing to take the risk. I have been looking at the grundfos UPA 15-90 amongst others. Any suggestions ?
Regards
Gary
Regards
Gary
