Whilst we have the current range of boilers and they are very efficient and all that good stuff, they don't seem to promise the longevity that the old boilers did. ..or even the reliability. Good news for CORGI guys of course but bad news for the consumer
started the post off.......
It is a pity no one else has come in because to you it may look "personal".*
But I say again, educate me..** link or show me the figures that prove why to fit my 72% boiler is virtually a crime in this country..
"You are saying modern boilers brake down a lot and provided no figures"
I did provide figures, the Sedbuk table, after your figure that older boilers ran as low as 50% efficiency! Try 30 - 40% lower you said, but my example runs at 72% efficiency 18% less than the best 'A' boilers and only 8% less than the start of the 'B' boilers (the ones that can be set up with a U guage).
You said "Those old boilers went down to 55-60% with age" so the new boilers do not reduce efficiency with age?
You keep saying "30 years ago" " back in the 1970's" What world are you in ? My example is to compare a 1990 boiler with little or no working parts, linked to a system with at most two (expensive) working parts, pump and diverter valve, with the best A boiler.
You see my world is where even the old cheap boilers, at 72%, lasted 20 years ! (very good for the environment)
The thread is about the environment and longevity of modern boilers, you make a statement to say that a "quality boiler" will outlast the older Ideal Classic type, now that is nonsense. At what cost? that is the whole point of the thread, your modern boiler
will last twenty years, but at what cost? your new boiler will not cost more to service/repair ? , it will not need new pcb's, or a fan or heatstats or diverter valves or pumps?
Just take time to read the first hundred posts (about boilers) on this forum, they prove my point, dozens and dozens of complaints about faulty pcb's faulty fans and components in modern well branded boilers. (Tony Glazier has just been to a three year old boiler with a siezed fan !) even the technicians on here berate some of the branded boilers as rubbish and not cost efficient, so where does that leave the efficiency tables, a new Worcester boiler 90% efficient but the fan or pcb packs in after three years? I am not making this stuff up just read the posts.
* You dont know me or my background but you say "The trouble with the likes of you is that you just don't understand boilers, systems and controls in any depth having superficial knowledge" and then you say do not take it personal? ...... in your words...what nonsense.
I like an honest debate or thread with anyone but, as I think you might say..., it's people like you who read the manufacturers efficiency tables and are blind to what is going on in the real world, the world where even the best boilers do not last without expensive repairs, where a £60 pump is 'adapted' to fit a combi and now costs £180, where there are now two pcb boards fitted to boilers at £100 each and when the pump or any other part leaks they may need replacing. How is this energy efficient? You have read how fuel efficient the modern boiler is so over twenty years it will have used so much less gas... but where are the costs for replacement extra parts over the lifetime of the boiler? The real world is the boiler would have been skipped ten years previously after having hundreds of pounds worth of parts fitted in its last declining years.
I know, in your mind, I do not understand boilers. So show me the figures show me how my 1990 72% boiler is, over a twenty year, period less efficient than the best A boiler .....
**Give me a cure 'doctor'
