Garden Path
27 May 2007
Essex
Hi
I wish to lay a garden path, I was going to use square brickets 50mm thick, could any one tell me how to construct the path base and what materials to use. Thanks for any advice.
when laying a narrow block paved area such as a path, then i tend not to use the:- lay on sand with compacter method, as the compacter, coupled with the risk of spread, can allow for an uneven pathway.
we tend to lay paviors onto a sharp sand/cement dryish mortar. this eliminates the need for the unpredictable compactor.
it does mean using a cement mixer though.
if you need to use edging kerbs then you are best just laying one edge first.
then lay the paviors, starting against the laid edging, finishing at a free edge.
then lay the opposite edge kerb, butting it to the paviors. this saves having to guess the width measurement. :wink:
Thanks, noesall. Any Idea what mix of sand and cement to use and what depth to use.
5:1 (sharp sand/cement) will be more than adequate. don't mix it sloppy. a dry almost crumbly mix will be ideal.
30-50mm depth of mortar bed would be best.
