Vokera boiler hot water activation arm stopped moving
31 Dec 2004
Last night my vokera boiler stopped producing hot water. I opened it up and noticed that when the hot water was turned on the activatvation arm (?) was not being pushed out as it should be. I was able to coax it to come out by pulling on it, but it was very stiff to move. When out the microswitch clicked, the boiler fired and the water got hot. It stayed fired whilst the water stayed on. -EDIT- This worked last night, but when I have just tried to have a shower, even though the boiler fired, the water didn't get hot, and it looked like there wasn't much gas burning through the little window. After reading a few posts it seems that it might be the diaphram. There have been a few other indications. The hot water has been cycling between hot and warm for a while, and I read that this can be indicative of the diaphram going. It has also taken more and more water pressure to make it fire over time.
Assuming it is the diaphram, any advice on how easy/difficult doing this myself would be? Which parts I'll need and where I might get them in Brighton/Hove? How much it should cost to get a pro to do it?
Any ideas what might cause this? Can it be fixed with a bit of oil/wd40? Any advice at all.
Thanks very much
Sam
I would not use WD40 as oil will cause rubber (if present) components to swell and fail.
I would suggest you get someone in to carry out a repair and service the diverter section. If the person carrying out repairs is familiar with the boiler, he will come armed with all components necessary to effect a repair that will last. If he is hamfisted and only replaces the diaphragm (no cleaning of internal surfaces or check valve withing domestic manifold), you will be blighted with same problem prematurely
If you can find him through local directories/web etc try Mark Payne (Vokera specialist) based in Peacehaven.
Aforementioned beam is only fitted to the excell model.
