Do you recognise this socket outlet?
Status
Not open for further replies.
21 Oct 2004
I need to find a match for this socket outlet - does anyone recognise the brand?
I think the finish is brushed stainless steel.
you have looked at the plastic mouldings on the back, haven't you?
I can't see the plastic mouldings from here.
The tenant took the photograph.
Hm. Definitely not the Volex - if you look at the screw holes they're not close enough to the corner of the plug holes.
I appreciate everyone's help though.
If the brush marks are vertical and the tops of the switch rockers are plain white then it looks exactly the same as some I bought from B&Q several years ago. I have one in front of me, the only distinguishing mark on the back is PIT*CS. The * being a solid eqilateral triangle.
RF has it once again.
Even if the original isn't a Contactum, it's so close as to make no difference.
Thanks! :)
Another option is Varilight brushed satin.
Looks exactly the same as the ones I bought around 6 or 7 years ago.
Status
