I'm fairly familiar with the principle of ground source heating but not too much of the detail. On last night's Grand Designs the building sat on 46 10-metre deep concrete piles, and wired to the reinforcing cage were loops of the heat pump pipework. (See http://www.channel4.com/4homes/ontv/grand-designs/houses/M/maidstone-bungalow-gallery_image3.html and http://www.channel4.com/4homes/ontv/grand-designs/houses/M/maidstone-bungalow-gallery_image4.html) This adds up to just about 1 km of pipework, not in one giant loop but attached via manifolds.
As the pipes are embedded well into the concrete, will they pick up enough heat from the ground? And at 1 km, won't this need some hefty pump to circulate the fluid around the pipes, and thus negate some of the energy gain?
There was also a ground air heating system, where a large dia pipe was set 1.5 mtr underground and air pumped through it, but I can't find any details of that.
I'm not criticising the program (although most of the grand designs I end up hating), I'm just curious about the techniques. the house isn't finished so there's no final test wether it works or not.
