Wind Power
  • Thread starter Thread starter toasty
  • Start date Start date
T
toasty
I've just started a new job and I'm based in Green Park, Reading.
I've probably driven past the place on the motorway (M4 J11) a hundred times, and always liked the look of the big wind turbine.
Anyway, I went for a walk over to the turbine today, very interesting it is too. Strangely it's not as big as I thought it would be, but it's still very impressive, they've got a little visitors area too with various information boards and a electronic readout of power generation.
It's apparently capable of some 2MWatts with sufficient wind, but today(being fairly calm) it was mainly reading 0.000MW although it did climb to 0.028MW (28KiloWatts) for a short time.
I took a few pictures on my camera phone, I thought you guys might be interested.
Here's a picture from the base of the tower:
click http://www.yourmissus.com/greenpark/pages/16042008077.html for a larger version
Here's the power readout:
click http://www.yourmissus.com/greenpark/pages/16042008075.html for a larger version
What was quite interesting was the way this turbine works (you can see the mechanics of it on the second picture) There is no actual gearbox in there, apparently the 'Annular Generatornator' is driven by the blades directly. I assume that this must be a DC generator which then feeds a large invertor (there were some large green enclosures round the back which made a fairly high pitched whining.
This idea (as apposed to a conventional gearbox system) seemed to work though, the turbine was very quiet as didn't produce the usual kind of whine you associate with these things.
Anyway, a fun way to spend your lunch hour, if you find this sort of thing interesting.
-Dan
p.s if you do, then there are lots more pictures (albeit similar) here:
http://www.yourmissus.com/greenpark/pages/16042008076.html
http://www.yourmissus.com/greenpark/pages/16042008078.html
http://www.yourmissus.com/greenpark/pages/16042008079.html
http://www.yourmissus.com/greenpark/pages/16042008080.html
http://www.yourmissus.com/greenpark/pages/16042008081.html
http://www.yourmissus.com/greenpark/pages/16042008082.html
http://www.yourmissus.com/greenpark/pages/16042008083.html
http://www.yourmissus.com/greenpark/pages/16042008084.html
http://www.yourmissus.com/greenpark/pages/16042008085.html
http://www.yourmissus.com/greenpark/pages/16042008086.html
http://www.yourmissus.com/greenpark/pages/16042008087.html
http://www.yourmissus.com/greenpark/pages/16042008088.html
http://www.yourmissus.com/greenpark/pages/16042008089.html
http://www.yourmissus.com/greenpark/pages/16042008090.html
http://www.yourmissus.com/greenpark/pages/16042008091.html
http://www.yourmissus.com/greenpark/pages/16042008092.html
http://www.yourmissus.com/greenpark/pages/16042008093.html
http://www.yourmissus.com/greenpark/pages/16042008094.html
http://www.yourmissus.com/greenpark/pages/16042008095.html
http://www.yourmissus.com/greenpark/pages/16042008096.html
http://www.yourmissus.com/greenpark/pages/16042008097.html
There is one next to the M25 between m1 and jnc 18.
its lit up at night, which seems to me to defeat the object of wind power.
novel idea, but did you know they can overheat and catch fire, firebrigade will turn up with long sticks and marshmallows since there is nothing they can do. try a search on you tube for the clip
yeah I had heard that, and I guess all the hydraulic oil and grease etc.. would fuel the fire nicely!! :twisted:
Best of all, working close to said turbine would mean that I'd get to go home early :lol: (H&S and all that)
As I say though, well worth a visit if you are in the area.
IIRC the way many modern wind turbine genertors work is to drive the field coils off a variable fequency inverter. By varying the rotation of the field they can make the generator generate at a fixed frequency whatever speed it is turning at and therefore they can avoid converting all the power to DC and back.
Yeah I had heard that, although this one does have an AC/DC/AC converter (see here - http://www.ecotricity.co.uk/acrobat/GPInfoPack.pdf - page 3)
You could hear it whining. I guess the AC going in is variable frequency depending on wind speed. Then rectified (AC -> DC) and then sent through a grid tied inverter to go back to AC.
Question though, 2MWatts (the turbine's rated power) is some 2800Amps per phase @ 230/400v 3phase. So presumably it gets 'injected' into the grid at a higher voltage? I couldn't see any substation transformers actually at the turbine site, but I assume greenpark has a large substation somewhere.
hmm yeah, where does the concrete go?! :lol:
I know what you mean, but those gaps are really big, that circular base is 14metres in radius!!!! And 2metres deep!! The picture doesn't do it justice.
So it holds some 1200cubic metres of concrete!!!!! That's 3000 tonnes of concrete
so if a truck mounted concrete mixer can carry 15 tons of concrete thats 200 loads, very green i say!!!!!!!!!!!!!!!!!!!
