my hot water runs cold and stays cold, however if I touch or knock the control panel of the boiler something clicks and the boiler will flare up and hot water runs through the tap. I have since lowered the control panel and I have not had any problems since.I have had the boiler for 3 years.
I've changed a few front panel switches on those.
An electrician probably wouldn't touch it (Far too thick ), someone with half a brain used to such things could probably find it in 10 minutes, lots of boiler bods would want to change expensive things like circuit boards, or the whole boiler.
Be careful who you call!
