Combi DHW goes hot/cold/hot etc
27 Apr 2008
Essex
Hi
I have a Potterton Performa 28 that is about 4 yrs old. Recently I have noticed that the shower goes hot/cold/hot/cold (thermostatic bar type). Other hot taps do similar but not as noticeable as the shower.
Now if I turn the flow down the situation improves so having searched on here and other forums the heat exchanger is suggested as being clogged up. My boiler has two, a plate HE at the bottom and another HE at the top. My question is which one is it likely to be or could it be both.
I am not a corgi person, but feel confident that I could remove both if need be, clean and reassemble.
Thanks in anticipation.
Steviev
plate h/e, replacement is preferable, but system cleaning may also be required/advisable
Thanks for that.
Whats the difference between them anyway?
Steviev
Presumably you mean the two HEs ?
If you dont know the answer to that question then I certainly dont think you would be competent to replace the primary HE as thats part of the gas train. Luckily its most likely to be the secondary which is the problem.
The primary HE transfers heat from the flames to the system water.
The secondary HE transfers heat from the system water to the hot water supply.
Tony
Before changing heat exchangers have you checked the thermistor,i would test with a multi-meter first against manufacturers readings,these only cost about £15 .
change them before you even look at plate h/ex
I'll bet a quid it's not the sensors! The secondary h/ex for one of these isn't expensive - hardly worth trying to clean it.
Thanks for all your replies.
Ive found I can buy a new plate HE for about £40 so ill order one.
Thanks again
Steve
Had the new HE delivered today and just fitted it. Seems to have fixed the problem.
Many thanks for all the advice
Steviev
