Hi in need of urgent help as Im completely mystified why my timer wont bring on the boiler weve just had fitted and ive tried everything I can think of but to no avail ......
Weve had a BAXI combination boiler fitted and ive got a Grasslin QM1 analogue timer which is basic or so I thought ......Ive got a 4 core coming from the boiler to the timer which goes into N , L , E then it has numbers 1,2,3,4 and the diagram says 4 is the "on" so ive put the sw line in there which goes to the number 2 terminal in the boiler which is the external input terminal and I removed the link in the boiler which the manual says between 1 and 2 if your having an external timer .............
Basically when I turn the supply on ive got 240 on the backplate so ive put the cover on flicked it to "constant" but nothing the LED doesnt even light up ..........
Any help whatsoever would be greatly appreciated as I cant figure out why it wont switch on as its a very basic system no stats or anything
cheers lads
cheers lads
