Excel: Lookup problem
18 Oct 2007
Kent
I want to create a lookup which returns data corresponding to a value equal or greater than the looked up value. If I use Vlookup it will always return the data relating to a value less than or equal.
For example: if I do a lookup for 1.5 and the first column of the array only contains 1 and 2, V lookup will return the value corresponding to 1. I want the value corresponding to 2.
Not sure if this will help, but an IF statement may do the trick.
=IF(A1>=F1,C1,"")
where A1 is the value you are looking up, F1 is your lowest value, C1 is value if true.
Doc Lenny
Not quite what I was looking for, but thanks all the same
empip
Very useful. Although it did not provide a complete solution, I did manage to work one out. My solution was sort the array in Descending Order and then use the Index and Match functions with a -1 as the last term in the Match.
Problem solved
Thanks guys.
Doc Lenny
empip
Problem solved
Thanks guys.
Hmmm.. I thought this :-
Covered requirements - without sorting... All code supplied for nix.
:D :D
Image deleted to save space :wink:
I'm sure you are correct. The problem is that it used functions and concepts with which I am not familiar, which meant that I found it difficult to understand exactly how it worked.
Sorting an array in reverse order was such an easy thing to do that I took the easy way out. When I have more time :lol: , I will study the use of arrays and the other functions. :)
