Hi All,
I've read lots of post already, but I have a specific scenario I'd like a bit of help with:
I would like to run mains into my shed at the bottom of the garden. I intend to run a lead out that is plugged into a socket in the house with a RCD plug on the end of the cable, so the circuit is always protected. In the shed I'll put a couple of sockets in, and I might wire a couple of waterproof sockets outside next to the pond to power a pump (despite my best efforts with solar power, it's just not good enough!).
I'm running the cable down the side of the house, and then along a very sturdy fence down to the shed. It's not going to be buried. So here's my question: Can I use normal PVC cable outside, given it will be protected with an RCD? If this is not good, how about arctic cable? I'd like to avoid the armoured stuff as it's expensive, harder to work with, and as I'm not burying it, there's no danger of anyone putting a spade though it.
Advice much appreciated!
Thanks,
Matt
Thanks,
Matt
