Can I Use This Shower Mixer Tap? (Moved from Plumbing and C,
24 Mar 2008
Leicestershire
ps. I was suggested to move from Plumbing and Central Heating, original post - http://www.diynot.com/forums/viewtopic.php?p=904077#904077
Hi guys just wondering if you can help me out here. I need to know if i can use this shower mixer tap from argos with my water heater http://www.argos.co.uk/static/Product/partNumber/8320627/Trail/searchtext>SHOWER+MIXER.htm
The part i'm wondering about is "The water level in the storage tank should be at least 1m above the hand shower."
In my pic it shows that the top of the current taps to the bottom of the water heater is 97cm but from the taps to the middle underneath the water heater is 100cm
Heres the sticker with details about the water heater
Thanks in Advance :)
Also heres the shower curtain im planning on using but i could always upgrade it as it looks like thats what it could do with :idea: :wink:
Not sure about that one, but usually you need a vented tap
Also as the plumber say , the element looks like it is above the bath which is not good.
Is the cold water feed mains of gravity? I hope you are not wanting to use it standing up!!
Maybe it is just me, but I don't like the look of that thing above the bath anyway!!
Looking at your edit, I don't think it will work anyway as there is not a 1m head from the water heater to the place where you will be using the shower head.
Are you sure you are meant to mount those water heaters above a bath? Are they suitable for installation in zone 1?
The answer to your question is No, it will not work!!
I'm questioning wether or not the manufacturer of that water heater has said it is OK to install it in zone 1 of a bathroom, it doesn't say in the spec sheet so I would at this point in time be inclined to say it is not suitable.
There is a phone number at the bottom of each page of the link you posted, maybe worth giving them a phone regarding the suitability of their appliance for being installed in zone 1 of a bathroom.
Well looks like im going to have to get on the phone to the council. Thanks for your replys and advice :)
If anyone else has opinions please let me know, cheers
Maybe worth speaking to the manufacturer before you phone the council.
Regarding the tap.
When the heater is on do any of the hot water taps connected to it drip.
If they do then they are vented taps.
If you removed and fitted your argos tap, you may cause damage to the heater, unless the heater can vent another way.
Looks in the data sheet that it vents into the cold water cistern , so it may not need vented taps.
Regarding the tap.
Hi, Thanks for your reply, None of the hot water taps drip
Just spotted the IPX1 rating!!
This is not suitable for installation above a bath, get onto the council!!
Items installed in zones 1 and 2 should be at least IPX4 so they should not have installed it there. http://www.diynot.com/wiki/electrics:ip[/QUOTE]
Hi, Wow, Thanks for the link, What are they doing, trying to kill me ! :shock:
Just wondering if you think this is ok to say to the council. " The heater is IPX1 which is only "Protected against vertically falling of drops of water e.g. condensation" Also if they try saying it is "Splash proof element cover" like it says in the spec sheet, what should i say, its IPX1 which isnt good enough, full stop :cry:
Just say you do not believe it should have been installed there as it does not comply with the IEE regulations (aka BS7671 Requirements for Electrical Installations), the person on the other end of the phone may not have a clue about IP ratings!!
If they ask why, you can always tell them the reason.
If you look at the link to the instructions , it says there it must be installed to the IEE regs, if you also quote the relevant IEE reg 601-06-01, it will confirm that it does not conform
Ok, Thanks alot, Much appreciated, Cheers
