I have used this forum many times to solve queries. So can I say thanks to all those people on here who make this such a mine of information. Second, apologies for the length [and probable stupidity] of this question/topic.
I reside in a 2-storey house. Currently, there is a back boiler fitted in the livingroom downstairs. The boiler and hot water/central heating work fine. The cylinder is situated in the bathroom on the first floor. The water tank and F&E tank are above this in the loft space.
I am looking to move the cylinder to the ground floor so I can enlarge the bathroom. The new position of the cylinder would be directly below the current position in the bathroom. The idea being that the existing pipework can be extended in a straight line.
As far as I am aware, even though back boilers are now a 'no-no' under the regs, there is nothing to stop me altering an existing layout. I do not intend to touch the boiler which is annually serviced and [fingers crossed] in fine order. Granted I will have to extend the flow and return pipes where they currently meet the cylinder upstairs.
Point here [and this is my stupidity probably], I am unsure exactly what I have. I BELIEVE I have a fully pumped open vent system. Both hooked pipes are in the relevant position in the loft and the system has two 2-port valves and a pump.
The new position of the cylinder will not reduce the head as this will, in fact, be increased. Is this an issue?
More to the point, as far as I can see, the hot water in the back boiler is pumped upstairs when central heating or hot water is called for. If this IS the case then what problems, if any, would there be in moving the cylinder position?
BUT.... not being sure as to whether this IS the case, I am wondering whether any of my system is 'gravity-based' because, if so, moving the cylinder to the same level [ground floor] of the house could then affect it. The cold water feeds would not be altered because the head would be increased.
I am wondering if the hot water [which comes off the top of the cylinder] pressure would be reduced accordingly.
Lots of idiotic questions I know but you guys apear to be the experts.
Before you baulk at a 'DIYer' thinking about this, rest assured that a proper plumber would be called in to do the work. That is, of course, if regs would allow him to do the work.
You're probably going to say switching to a new combi would be better. However:
(a) I have no gas connection anywhere near a potential combi site
(b) With teenagers, I am not sure the amount of hot water usage would be satsified with a combi
(c) I have been quoted £3.5K for the work and, at present, this is not affordable.
Thanks again,
Now for the 'onslaught'!!!
Thanks again,
