I need to cut into the cold water supply to my ensuite tap to change a leaking compression joint and move the hot/cold supply pipes forward into a new false wall. The cold water tap must be connected to the rising main as when I turn the main stop cock off under the kitchen sink this isolates the water. Given this, I only need turn off this stop cock and not drain the cold water storage tank in the loft do I?
I realise that the pipes will still be full of water when I remove the comp joint so will leak until the water in the pipes is clear.
