Polypropylene waste pipe
16 Sep 2004
Leeds
Why can't Polypropylene pipe be used with solvent on the connections?
Is it ok to use 'pipe weld' on this typr of pipe or do I have to use push-fit or compression?
Not really sure but the only time I used polypropylene pipe was externally and the fittings were all push-fit. The only thing I can think of is that it's supposed to take higher water temperatures than ABS or MUPVC, so whether there's an expansion issue might explain it.
Thanks.
Don't think Polypropylene pipe is suitable for exterior use. Something to do with no UV protection and it becomes brittle (or something like that)
It was only for overflow from roof tanks. It had to exit close to walkway so had to be brought down the wall, customer wanted black and it's all the local merchant had hence only time I've used it.
