Hi All,
I was just looking for some expert advice re plasterboard types \ sizes. I am still planning a new bathroom for my home, (been planning for what seems like months now
). The bathroom will be completely tiled on the inside with fairly large porcelain tiles.
I am currently planning to use Aquapanel for the inside in 2400 x 900 panels. In total i've worked out i'll need 11, which at £35 a pop is quite expensive. So my questions are:
1) are 2400 lengths the best size? Seems to make most sense to me as I can go straight from floor to ceiling. The reason I asked is because its been mentioned to me to get 1200's and work horizontally, although I can't figure out why this is preferable.
2) i'm now thinking of doing just the immediate shower\bath area in aquapanel to save some cash. Would you recommend this and if so what plasterboard should I use for remaining areas?
3) two of the walls are brick, (inc part of shower wall), and I would like to dot and dab plasterboard onto brick. Is aquapanel OK for this? I've read conflicting messages on this subject on here so just wanted to get a bit more info if anyone has it.
thanks again
thanks again
