Extending flue pipe.
2 Jan 2006
Northamptonshire
Hi, building an extension at the moment and the wall from which my flue went through has been moved further out by about 500mm so I need to extend my flue by this amount.
The flue goes up from the boiler about 500mm then a 90 degree elbow and then horizontally about 500mm but this will need to be about 1000mm.
The boiler is a Vaillant but not sure which model without closer inspection.
Is this a diy job as there doesn't seem much to it or is it specialist job?
Alternatively I could move the boiler over by 500mm as most of the pipework will have to be re-routed anyway.
Whats the pros and cons for both jobs?
Also are solder ring fittings easy to use, as I have quite a lot to do and they are quite a bit cheaper, only I have ever used compression or push fit?
If the easiest option is to move the boiler, then move it, if you have a plentifull supply of fittings then feel free to do what you want!!
how can you move a boiler and leave flue where it is :roll:
Because like I said, the outside wall has been moved out by about 500mm, so if I move the boiler across by 500mm then the flue will not need to be touched.
Post Deleted.
Please do not give advice on work which would be illegal for someone not competent
Mod
