Need one of these
11 Jan 2007
It's a 3-phase 30A MCB. Made in England by Federal Electric and it's got Stab Lok printed on the side.
Does anyone know where I can get one from?
[/img]
Good luck!!
I think that TP federal MCBs are one of the hardest parts on the planet to get hold of. :cry:
I have a couple of SP ones, but I don't suppose that is much help
There's an MCCB here, however the company are, apparently, suppliers of "new, obsolete and discontinued electrical equipment."
It might do, but is it a 3 pole (3 phase) version you are after? Or a single pole (single phase) version?
I will take a look, I am sure there is a couple at the office - a TP and SP I recall, but not sure on the rating. I think they are the ones with coloured dollys though....
They are certainly not a current DB, and are probably coming up to renewal age, but they can't be condemned on sight, as you wouldn't condemn a BS3036 wylex board just for being old.
they tend to not have finger guards, easily touched terminals and are generally death traps.. nearly as bad as the 3phase fuse boards we have at work, where your hand is touching the exposed busbar above while you put cables into the row below..
I must admit though that those look better that other examples I've seen of FE breakers..
http://www.inspect-ny.com/fpe/fpe.html evidence against continued use...
