I must admit I have not opened up the consumer unit, which would possibly answer this very quickly.
I have a lighting circuit, which only provides 3 lights (I hope) in an extension of a house, which was built around 10 years ago.
The three switches in this extension have been replaced with some electronic switches off-the-shelf. The lights are 60W standard lights, these are suitable for the switches.
I believe that the live and neutral in the CU have been swapped over.
I have attached a layout diagram of the three junction boxes which service the switches.
The junction box which is between switch 1, and switches 2,3 is wired, red to brown, black to blue.
The diagram has the following labels as inputs to the junction boxes:
I: Input cable
S: Cable to switch
L: Load (light)
O: Output cable to next switch
The first switch works as expected. The second two switches do not work correctly.
I believe:
1) The first switch is either actually switching the neutral on the load (I was taught this was a bad thing)
or:
2) The live and neutral on this circuit are reversed.
Is there any easy way I can tell this without opening the CU? (given the state of some of the things here, I wouldn't be surprised if a dead something fell out).
As switch 1 works, switches 2 and 3 don't I suspect 2 is the correct 'fault'
Thanks,
Gareth
I: Input cable
S: Cable to switch
L: Load (light)
I believe:
or:
Thanks,
Gareth
