Danfoss HS3 3 Port Motorised Valve is faulty central heating comes on with hot water, can i replace this with a different make or does it have to be replaced with the same model
As long as they look the same from the outside, most of the nuts on Honeywell, Sunvic and other valves are the same.
If you buy another HS3 complete, you can take all the moving parts from the new one and put them in the old one without removing the brass body of the valve from the pipes. Some might consider it fiddly but it only takes a couple of minutes.
