Roof Insulation
10 Apr 2007
Humberside
Appologies guys if this isnt in the correct section not sure if it went in here or under roofing,
what is the current requirement for insulation in a single storey extension with a mono pitched roof, will i be ok with 150mm rockwool ???
Used to be ok at 125mm asking for 140mm now ( only a rough guide depending on different grades brands etc) best to confirm with local bco but I know we are looking for up to 140mm now.Also depending on where in the roof space it is to be installed , as different applications have different u value regs.
