vented hot water clinder
6 Aug 2008
I am trying to conect up some solar hot water panels "which were here when i moved in but dissconnected" through a vented hot water cylinder. Prob is the main storage cylinder is presently fed by mains water although the mains presure is regulated down around 1 bar. This regulator on the mains feed can be turned down even lower so can I reduce the presure on that regulator then have the flow pass through my vented cylinder "solar cylinder", pass on to the main cylinder but add a vent pipe to the main cylinder which is the way the main cylinder used to be set up?????
ever wondered why it was disconnected :cry:
From what the previous owner said, i was that they were disconnected because it was costing him two hunderd pounds each winter to have the system bled. this brought me to the conclusion that he had domestic water going directly htrough them instead of being indirectly fed through a separate cylinder!!!!
