Wiring in Loft
13 May 2008
Bedfordshire
Just been up in my loft to see what I could do about putting down some loft boarding down.
Now there are a fair few what look like steel pipes running over the joists with wire connecting to them every so often. Now there are the more upto date grey electrical wires up there but is the old stuff likely to be still in use? I take it is old wiring, something like the nub and tube stuff you here about on Holmes on Holmes?
Certainly puts a kink in my good intentions!!
photo's? we like to see stuff like this..
and no, not really put a crimp in your plans..
the residents on the "floors, stairs and lofts" section of the forum tend to recomend putting timbers across the loft joists and the boards on top of that..
Knob and tube. And no, that system was never used here. Thank god.
However, steel conduit wiring was and still is used. In a residential house though, its likely to be very old. Only you can see if its still connected to anything. Photos of these "joints" would be nice.
Bah humbug I've just packed everything away :( Unfortunately I don't have a loft ladder so it's a matter of getting a ladder upstairs each time I want to go see the loft.
I shall be up there again tomorrow so I shall take a pic if I can. Not only do I have those I also have other joists, 3 or 4, going perpendicular the on top of the others, it's never easy is it?? :cry:
As has been said, it is likely to be black enammeled drawn steel conduit, and probably contains VIR cloth covered cables, dating from around 1930ish.
It may still be live. Plent of it still is, although if it is it needs to be replaced.
If you have modern cables in the loft then hopefully it has already been disconnected, but left in place as it was easier not to remove it.
