I'm moving from a system boiler to a combi in a property we have just bought. It's a 2 bed bungalow with 1 bathroom and a total of 6 rads. The existing boiler is in the kitchen but I am going to put the combi in the airing cupboard. This seems to be the perfect location as there is an outside wall, hot and cold water pipes, and the heating flow and return run from the kitchen across the loft and down through the airing cupboard and under the floor to the rads. There is a suitable electrical spur circuit and I already have a wireless programmable stat. I have removed the old hot tank, pump, diverter valve , tidied up the flow and return pipework and fitted a filling loop. All rads bar one have TRVs and I have flushed, pressurised and tested the pipework. The gas pipe runs in 28mm pipe directly above the airing cupboard so all the installer has to do is divert the gas pipe down into the airing cupboards and "plug and play" the boiler.
Despite this, I am getting quotes of around £600 more that the specified boiler costs. This seems extortionate to me for what will almost certainly be less than a days work for one guy. Is this a typical price for a days work from a Corgi engineer or am I being ripped off? The property is in Devon, if anyone can recommend a more reasonable installer, or if there are any installers in the area who would like a nice easy install.
Also I am getting the usual conflicting recommendations on boiler makes. One recommends Ideal and says Worcester are overpriced another says Ideal are rubbish and "Vaillant are the only one I would fit". Any boiler recommendations gratefully received.
