AEG Electrolux ARCTIS A75108GA Warming Up?
10 Nov 2010
Leicestershire
Just thought I'd share a solution to a problem we've had with the above frost-free freezer...
After a years use, one day we saw the temp start to rise (it has an LED display). Just outside the warranty, we were pretty ****ed so called the company we got it from who were useless. While we were deciding what to do (I hate calling people out to fix things before I've had a bash myself), we moved all the food over to our other freezer and turned it off. Low an behold, when I turned it on a couple of days later, it got down to temp fine and stayed there.
A few months later it happened again so I attacked it with a hairdryer to give it a quick de-frost. Job done...or so I thought....
It started to happen on a regular basis so the other day I decided to take off the panel at the back (on the inside), you'll need a 7mm, thin walled socket, and found why... ice had collected and built up behind the panel in a drainage recess. After an hour or so of hairdryer action (be careful not to melt anything or electrocute yourself!), I could finally see the drainage hole which leads to a little rubber tube at the back of the freezer, above a plastic condenser tray on stop of the compressor. The tube was a little blocked, not massively but obviously enough to cause it to stop draining and start collecting in the freezer.
So to re-cap, remove the inner back panel, defrost, unclog the drainage hole and you should be fine :)
Warning signs of this issue seem to be ice streaks forming at the lower, back part of the freezer, emanating from behind the inner back panel.
Also a little trick is to put a thin piece of copper wire on the defrost heater and the other end in the drain hole go down about 3 inchs and if it gets blocked again the defrost heater will come on and the heater down the copper wire will melt the ice. Defrost heater will come on twice a day.
For the second time in 2 years our AEG freezer has gone wrong :evil: (won't stay at set temperature) requiring a new thermal cut out - part number 2426484172. Anyone else had the same problem?
Pleasingly the part has come down in price over the last 2 years but the frustation of things going wrong makes me wonder if it has been a built in fault to keep service engineers busy!! :mrgreen:
