PROGRAM TO RECORD UTUBE?
26 Jun 2004
London
I have a very slow internet and I would like to be able to record HD YouTube .
Any suggestions?
or try www.keepvid.com
copy the address of the youtube video you want and paste it there. It will give you options of various qualities and select 720 or 1080. Note that not all youtube videos are in HD.
I remembered I did a guide once...
LOL!
If you are skilled enough to follow @Monkeh's suggestion for downloading YouTube video streams, and get it to work seamlessly with your browser of choice, you should be at least clever enough to always use end-to-end encryption, run your Internet activities via anonymous proxies on TOR, edit your hosts file to block all agency snooping, and write the rules for your firewall to block the Baidu tracking, but thanks for pointing Baidu's insecurities out anyway.
No other browser or search tool has insecurities, or uses tracking...
...do they?
(By the way, whatever browser you use, your ISP knows and reports everything you do online to GCHQ, and probably the CIA and any other spy network that has the capability of tapping internet data from fibre and electronic pathways between you and any server you choose to receive data from.
Caveat!!: Only use Baidu for YouTube and streaming downloads, and not for your online banking or everyday browsing etc.
Always wear one or more tinfoil hats, since they can and will listen to your thoughts, if you don't protect yourself!
