Getting fridge out of tight space?
12 Dec 2016
How do I get this out? It's in really tight.
Use some neat washing up liquid on the floor as lube, empty it, and pull near the bottom.
Ask Grandad to help out.
Nozzle
Slide a 10 pound note under the fridge,. tell your teenage son it is theirs if they can get it.
if the feet are stuck to the floor, you may not be able to spray furniture polish under them. But if you push it to tilt it, you will probably get a gap big enough to spray into.
Once it starts to move, it will probably glide quite easily on the furniture polish.
AFAIK polish does not go sticky, then hard, as it dries, like WUL does.
Once you have the appliance out, scrub and swab the floor very clean. Kitchens tend to accumulate sticky deposits due to cooking.
Is there's space you could get a sheet of hardboard, shiny side down (rougher side up), tilt the fridge back and slide the sheet in under the feet (getting the back ones on is sometimes tricky), once it's on you you should be able to pull the board from the front with it on top.
Just spray some soapy water under the fridge making sure it goes around the back feet. It will slide out and back easily.
