Hi all,
so got my new DeWalt DW745 table saw. it has dust ports on top of the riving housing (36mm i think) and below the blade at the back (54mm i think).
Now ideally i'd love to be able to hook up a vacuum to both at the same time, so i'd need a split flexi-hose with the correct adaptors. I'm thinking same size hose connecting for both, so i'd be using the reducer on the back as opposed to fitting a 54mm hose directly to it.
Anyone tried this with any measure of success?
I currently have a hetty cleaner attached to my DW777XPS, but thought about making or buying a cyclone to avoid clogging the old girl up. Would adding a cyclone into the mix reduce suction? Especially if i want to split the suction tube to go 2 ways?
All advice appreciated.
Cheers
Cheers
