Should UPVC doors be level and square, I've had one fitted and although the frame is level the door is out of line and level so visually looks not good. One would assume if the frame is level the door should follow suit. Also the face-mounted hinges are not square, they are angling down. There is no adjustment on these as they are factory fitted, comments welcomed.
