Will keep this short. I am converting a garage to a hobby space, cut the garage in half with a stud wall and because I am a muppet and messed up the doorway it’s a bit on the small side.
It roughly measures 56.5cm by 202cm. The smallest door I can find in Wickes or similar is 61 cm and you can only shave a little off.
So any suggestions on where to get a door or what to do? Too far along to make the opening bigger so that’s a no go.
