UFH Worcester Greenstar 8000 Life
23 Feb 2024
I’ve been asked to wire in the UFH to this set up for the boiler. I’m not too clued up with wiring up heating systems but have done a few.
This one is mainly throwing me off as the bosch thermostat for the central heating is in use which I believe is a smart, plug in card to the boiler rather than a normal hardwired thermostat.
Would anyone be able to help/give any advice for wiring this up?
I'm no plumber/spark, but I see you have two zone valves, think you need two thermostats, one for each valve.
Then you can run the house rads and UFH separately.
Thanks mate. Yes I think the main bit I’m struggling to get my head around is they’re using the Bosch stat for the heating currently which is a smart one and has a card that plugs into the boiler. I’m not sure how to wire the zone valve in with that thermostat.
