No hot water this afternoon. Vaillant 418 EcoFIT Pure, open vented system, 3-port valve, VRC 470F, VR 65, VR 10 thermistor sensing cylinder temperature.
Reset it to clear fault, and try again , and now getting the near constant pause symbol, though had it actually purge, and fire the boiler briefly, a few times. Checked loft header tank, 4" of water, checked flow and return sensors d40 d41, and they agree with my add-on pipe temperature sensors. 3-port seems to respond correctly.
Throughout, I have not heard the circulation pump run, or seen it's LED come on. Pump is fed/powered directly by the boiler. My next stage of investigation, is to power the pump up from a 13amp socket - but not for a couple of days, I am too busy on other things.
Has anyone any alternative diagnostic suggestions?
