Hi All, I had a long installed I-on 160ex installed prob nearly 10 years ago, but wanting remote control from mobiles required me to migrate to a i-on G3MM.
There are two wired expanders + the main panel + 2 keypads all wired.
Swap from 160 to G3mm was just a swap of the main panel, expanders (and zones from them) and keypads stayed wired as is on the other end
Most of the time, alarm works as expected, if the alarm is not armed, the chime activates when set doors/windows opened. Monitoring on the panel shows resistance is good (4.7k/2.2k) for all zones setup.
Occasionally, the full alarm will activate (ie bells sounding) when disarmed. No errors on the panel or app. no indication of a tamper etc. Any ideas of where next to look short of removing each zone 1 at a time? (as above, all zones show correct resistance values when checking!)
