- Joined
- 27 Jan 2008
- Messages
- 27,570
- Reaction score
- 3,332
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
At the moment removed, and re-programming it, waiting for the last cat to turn up. This is a last ditched attempt before we buy a new cat flap.
With two cats, it seemed to work fine, then we got my son's cat to look after, and she was not use to using a cat flap, so started by clipping the flap up, and then setting it to allow all to enter, so latches down.
Then it seemed one female on heat, so set to correct chip only to enter, and it, in basic terms, stopped all entering, correct chip or not, but when we switched to allow all the green light was still going on as our cats came in and out, so it seemed the flap was doing as it should, and may be the cat was not trying for long enough.
Not helped as the cat has worked out it can get claws around the flap, and open it in the wrong direction.
The flap is made by PetSafe, (Radio Systems Corporation) but what I want to know, is how others get on with this type of cat flap, should I replace with a different make?
