Not sure what the point of the exercise was but the numbers are interesting.
I think we all do (or should) accept that the "current carrying capacities" we work with are very conservative., They presumably represent the current which will, with the installation method used, raise the conductor temperature to its 'rated' level (usually 70°C or 90°C) - but I imagine that it would require much higher temps than that before the cable suffered any significant harm, let alone became a 'fire risk'.I remember a few years ago someone on here connected a length of 2.5 mm copper wire across his welding machine and ran it up to 80A without blowing it ( securespark I think but not sure ) I think he was demonstrating that the rated current carrying capacity of cables is underrated.
Perhaps a bit 'pedantic' - but that oft-written statement is clearly not true.I guess the current takes the path of least resistance
Not sure what you think was "strange"It's strange what happened there though
I would consider a wire smoking and the insulation falling off to be "failed".and above my paygrade but in actual fact neither of them failed as such.
While it's probablly true that ratings of the cables we work with day to day are conservative, I think it's also true that this video presents what is very much a "best case scenario" and could lull people into a false sense of security.I think we all do (or should) accept that the "current carrying capacities" we work with are very conservative., They presumably represent the current which will, with the installation method used, raise the conductor temperature to its 'rated' level (usually 70°C or 90°C) - but I imagine that it would require much higher temps than that before the cable suffered any significant harm, let alone became a 'fire risk'.
Yes, that's quite possible, particularly given that it takes very little to 'lull some people unto a false sense of security', in a similar fashion that it can also take very little to unnecessarily 'frighten' some people.While it's probablly true that ratings of the cables we work with day to day are conservative, I think it's also true that this video presents what is very much a "best case scenario" and could lull people into a false sense of security.
Probably long before "the insulation loses it's integrity". From the characteristics of MCBs, we know that our cables are deemed to be 'safe' with a current up to 1.45 times their 'rated' current-carrying-capacity for about an hour, and I suspect that all that happens at 1 hour of 1.45In is that the conductor reaches its 'rated max temp' (which, if true, would be well below a temp that would do significant harm)..... And of course we protect them with fuses and breakers that don't trip the instant the current goes over their rating. There needs to be enough margin in the conductor ratings that the protective device trips before the insulation loses it's integrity.
