- Joined
- 20 May 2021
- Messages
- 120
- Reaction score
- 1
- Country
Does anyone know what kind of 110mm connections from the WC can make this piping arrangement (where I can put put a AAV behind a WC stud wall)?...
Is it a concrete floor?
If you hide an AAV behind a wall, it will be a lot if effort to replace it when it jams and stinks the house out (which it will)
Why do you want an AAV? Where is the nearest vent pipe? Where is the nearest external wall?
And where is the nearest vent pipe?
I guess you can avoid siphoning the basin and shower by using a Hepvo or similar waterless trap on them.
I’m unsure whether you need an AAV anyway for the toilet, with that layout. How much drop is there on that 3.5m run?
Digging up the garage floor and attaching to the clay pipe lower down is really is going to be a massive faff and I assume raises all sorts of risks if that piping (probs clay piping in old 1940's house) get damaged.
Everyone wants a simple solution, but if that won't work... Guess what!
I'd put one in.
2" should be ok.
As I always say... "it's better to be looking at it than for it!"
