I think the problem is the soffit. Its soft uPVC sheets so you can't leaver against it.
Can't knock plastic head off either without damaging soffit.
I've only used a wide ened punch, then you end up with a small hole.
This has been the Bain for me when doing facias, the pins I've used at the smaller ones and strong when fully knocked in but minimal mistimed hammering and I was knackered.
I found the only way was to plier and pull and try to gradually get lucky, not easy with force needed if on a ladder.
I ordered some hole punches but they never arrived in time but was going to try that.
I think if a tool manufacture made a tool capable of removing pins they'd make quite a lot of money.
