I need to buy these screws and would be grateful if you can advise which type, which screw driver and if I need to pre-drill a hole?
Over time, the retaining screws on my door handles seem to work themselves loose, causing the handle to wobble and eventually fall off. To make matters worse, my last carpenter — the lazy swine — only used two screws instead of four.
I’ve now seen this same issue in three different houses, across three different handle styles, all installed by different carpenters. So I’m starting to think this isn’t just bad luck — maybe it’s a design flaw.
- Are these handles actually fit for purpose?
Can these tiny screws really withstand the constant load and shear force from pushing, pulling, and twisting the handle, or are they just a cheap, outdated gimmick that needs to be retired? - What exact type of screw and screwdriver should I be using?
I keep damaging the screw heads whenever I try to tighten them. I know people will say “don’t overtighten”, but if I don’t, the handle isn’t secure. So what’s the correct screw type and the right driver size to avoid stripping the heads? - Should I be pre-drilling the holes?
If so, what drill bit size should I use for these screws? I want to do it properly this time rather than chewing up the wood or the screw heads.
